problems edit definition engine mechanism creo 3.0 m090
  • Thread starter Thread starter davide_pontini
davide_pontini
Good morning.
I have the following problem: I find myself in mechanism environment and from the model tree I want to change a motor that is contained in a subaxieme. All right.
mechanism makes me transparent everything that is not part of the subaxieme and shows me the body connected. All right.
When I come out of the modification definition I find that I create saved the transparency inside the orange gallery, so that all that was transparent due to the momentary deactivation remains transparent.
I tried to change the config value of the dim_inactive_components --> never but with this particular action there are no changes, it continues to become and remain transparent.
Has anyone happened? with a previous release of creo 3.0 you have the same problem.
Let me know, it's an operation I do many times and it starts to be annoying to make clear appearance every time. . .
thanks in advance of the answer
