daniele.g.65
Hello everyone, I noticed that sometimes, after making a sheet body and explaining it, while having a correct representation of the direction of the folds (up, down or + , -) at the time I go to create a sheet
of drawing, and on which the explained sheet is placed, it can (as mentioned, in some cases), without which I can do otherwise, position on the sheet, so that it will be speculated, while maintaining the initial, correct bend indications, that is up or down. If I do not notice this "variation" from the initial explained, the result will be to bend in opposite direction to the correct one and to throw away the wrong piece.
I do not know how to overcome this error, and if and how it is possible to check that the explained sheet is represented
on the drawing sheet, equal to the dxf, that is in the same way as how the sheet is cut, which in my case being
in most cases, satin-finished and protected stainless steel, external view with satin finish and protection facing upwards.
Moreover with spaceclaim, compared to solidworks I can not move, (translating, turning) the bend directions.
it would be easier if they were automatically oriented along the fold line, as well as it happened with solidworks, which
it also allowed them to rotate and move them to their liking.
