problems installation revit 2011 -ribbon
  • Thread starter Thread starter render54
render54
yesterday I wanted to add something but I waited
because in the morning I had arrived 2011
I installed it in the late afternoon
took over 2 hours to install (view 64)
has given error on netframework etc.ecc.
when you start from a window of errors that you do not find here and do not find the
when it is open for now I have seen that you do not see the command icons draw
I opened a default design and sent it to render and went
today I remitted the cd to see if I could remake the installation but I must uninstall it
first
Two more hours?
a question: Can I put these time losses into account to the autodesk?
uninstalled and reinstalled revit 2011
but the problem remained
I will hear the dealer technician who provided me with the program
is a problem related to the installation files of the version in English.., I to solve the problem I had to remove all autodesk folders (including those of autocad), and reinstall everything, and after did not give me the error.giuro that I will no longer install a version in English!
in fact I had downloaded from autodesk a verse in English for 30 days that then expired I uninstalled
They're good, anyway!
to wish of frank the discussion was moved here-quo-qua
http://www.cad3d.it/forum1/showthread.php?t=20024and boys how I understand you. In my humble opinion the sw go towards a philosophy that provides machines with medium high performance and therefore the cases are not lacking. I personally installed in May 2011 without problems, well one that solved me on the flight the great frank.
a doubt???? but will some autodesk programmer read then sti forum?? I participated in the live chat organized in April by autodesk and the impression was that on specific questions these did not know that fish sieve;o(
and as the magito toto said... and ioo pagoooooo!
say I have to uninstall revit 2011, revit 2010, design review and true view 2011? and delete the folders of these programs and then reinstall everything?
Hi render,
but what I can recommend is this: wait to uninstall everything, buy a good program for cleaning the logs does not seem but sum up errors that you do not see but that affect the operation of sw and machine.
start with ccleaner is free or quad registrycleaner or www.uniblue.com But you see.
When you cancel a program many parts remain still active and hidden for this you need a general cleaning, like those of spring :biggrin:
In fact I didn't do it at the end if they were just those icons that you don't see but the command looks like the answer first, if they answer me, of those of the one team that I sent the images of the error, then it must pass my technician and I do it to him since I have to fix another thing
