problems with catia v5 user interface
TheBest
Good morning, I got caia v5 r21 through my school, I installed it this morning but opening it I noticed that the interface you use is disproportionate, I tried to look at the settings but I didn't find anything, do you happen to know how I could fix this problem? thanks in advance for the answer
I don't know how to insert an image on this site, so here is the link with the image of the disproportionate user interface that I find myself: png: immagine 2024-04-21 183019.png
follow these directions: by selecting the branch of the tree in the window.
bhe thanks, but it did not serve me at all, however I have activated the text of the various settings, the various plans and the manipulator of them remain small
apart from the option there is written that you have to place the pointer on the branch, then holding down the central key move the mouse back and forth and the writings change accordingly. It works for sure!
for the size of the floors and the manipulator are other settings
per i piani:
it worked, thank you very much, sorry if I still bother you but how come when I try to perform a hole if I click the sketcher to change the position does not appear to me the white asterisk of the hole?
verify active/disactive icons in the sketcher bar you will have disabled something.
