peccato
Hello.
I'm learning how to use revit, I'm working now on the 2020 version.
I was doing tests with the stairs command to learn.
I don't have any big problems creating the stairs, but for exercise I was trying to create some central-mounted type and lean steps without lifts. I can easily activate the right and left supports and vary the parameters to adjust the appearance.
instead putting the check on central support I can not generate anything, no errors appear, imposed values in the menu type central support but the sw does not generate anything.
I even tried with side support and offset and managed to do the central mount but since I am learning I want to understand why there is a central support function and why I can't make it work. I tried both with stairs to raise nothing and at default ramp scales and nothing does not want to know how to generate something or give me some mistake to understand how to move.
I've been looking for the forum all morning, but nothing.
I add that I am trying on a straight staircase ramp very simple and not on multi-storey or articulated stairs.
Thank you in advance.
