problems with development double curvature surfaces and fold
  • Thread starter Thread starter MarkC
MarkC
Good morning to all
I'm new to this community and I've been using rhinoceros for a month so I'm calling myself a neophyte of the program with little knowledge.
SRF_3.webpSRF_2.webpSRF_1.webpfrom attached images you can notice a folded srf on the edge, I must straighten it (already made an attempt with the fold command bend without results) and then develop it to find the area of the surface.
here comes the second problem being double curvature surfaces I can not use develop surfaces.
Is there anyone who can help me?
cordial greetings
test with surface control points change > control points > activates control points, helping you with the smart track function near the object snaps to get more precision.
can follow the council of sibillo,
if not try with the flatten or smash command.
hello to all, I am also neophyte I have always used acad lt and I have the same problem, I have to straighten a fold on thickness 0.8mm, you could explain step by step the procedure because so I did not succeed, I think ideal for me would create an intermediate surface and develop that.
I press that I am using the evaluation version to see if these things prescribe me to work well, so I did not do the course and I am zero (I will do it if and when I buy it) but first I would like to understand if the program allows me to do these functions
thanks to all especially for patience.
Obviously yes. besides the splop (it seems to me it is called so but I do not use it for a while and I do not have rhino subhand) there is the command previously described now included in rhino 5. on the mcneel wiki also find the procedure. in any case the command is _squish and there are numerous parameters and including deformation analysis.
