problems with display and rescue
  • Thread starter Thread starter Michelefi
Michelefi
It's been this morning that every time I open this axeme file, it shows me this message, but above all I have problems in displaying some machines. . - Does anyone know how to give me any explanation? Thank you.problemi inventor.webp
usually when the hateful window is the inventor that "wrong" which was made a change on one of the components of the underarms and until you open it and save it that window remains there
Thank you, but I don't know where to start since I have a myriad of pieces, I'll look into the last axioms I've modified.thanks again
click on the third bus to the right of that window, there should be a possibility to exclude that message.
I thank you but I have seen it...the problem is not so much the message, but since I have the messaging I have problems with displaying the whole set and every time asks me to save continuously
If you don't want to know how to leave, there would be a highly barbaric solution......... a pack and go.... If you work without a vault it's not a big nuisance to make a pack and go, to open it to be sure there's no rhymes above and in case of positive outcome delete the old files and replace them with the new ones.
More than once, I've been doing this for too messed up projects (moved here and on key drives and hard disks and with a lot of people who put the amnes on it)
I don't think of less drastic solutions
