oq172
Good morning, everyone.
I have a problem: I have to bend a strip of sheet to u, after the piege I have to cut a 45° edge so as to joint the u to another cut in the same way. if I cut the particular in the ipt file when I create the flat model inv obviously brings back the cut as it should be if I worked directly the part before bending it (which I do not want). now how do I create an assembly with the various pieces cut to 45° without processing modifying the originalhypt?
thanks and good Easter to all
ale
ale
