peloritano
I have a problem that until now I have always been around but that I would like to solve....
I practically have a surface like that in figure consisting of two vertical walls and a horizontal wall. ....
my intention would be to perform a workmanship in which the spherical tool climbs on the vertical wall then cross the horizontal wall and then rejoin the other vertical wall and then reverse the motion and continue to zig zag. for this use a sweep processing but the result is that in figure, that is, the only horizontal wall is worked and the vertical walls are completely ignored.
Would someone more experienced than me know how to do that?? Maybe I can use some other workmanship or maybe insert some particular paramentro... the only warning is that the tool axis must be fixed and perfectly vertical.
Do the other cams have the same problem that I encounter with catia?? ?
