product generation vuoto
  • Thread starter Thread starter colosso84
colosso84
I would need to know if there is a way, or a program, to make so generate automatically automatically an empty product, that is without all under internal components.
to explain me better es:
product original--
product emptied --> only outer shell
Thank you very much
you just need to use the assembly variants (Icon: yellow case with three squares).
start the command defines parts of/and variants
then through the command creates variant create the new model.
I'm sorry, you can attach the command icon and where it is. Thank you:
a is the command of variant of assime
b is the command of creation of variant of together.
The latter throws it together closed.
Do you use it as a command?
especially for what?
Hi:
to make prototypal stage more configurations than one machine.
at the end the final configuration is extracted.
the problem arises if you have to deal with non-native pdm, the latter will eliminate most of the flexibility of the cad.
Who knows if one day someone will understand.
Hello next!
