production design
  • Thread starter Thread starter gantoniol
gantoniol
Good evening to all, I press that I ran a search in the forum but I found nothing. I suggest that for work I use autocad lt and I also own the license of revit lt. recently I started a collaboration with a study of plant design that could become perpetual, hopefully, and I wanted to ask users of the forum of advice, at the level of software to use and procedural methodologies, in order to implement the productivity in the processing operations of the design elaborates, also to use for the processing of computs. thanks to all the advice you will give me and good evening.
switch from your revit lt to revit and start using the mep part. in the coming years, even in view of the new code of contracts, the small professionals working with autocad lt will be cut off from the games
good day tristan, thanks to the advice, I had taken into consideration the idea but I the fact that revit is available only in subscription with prices for me inarrivabili has tarpato i wings.... in fact I was looking for a perpetual license "used"....
revit licenses are not a good idea at all because the files are not retrosalvabile and when you are working with "virtuous" you are still out of the games
:oops: I had not thought about this! so the only solution would go to the subscription version. . .
