program from vba to vb.net
  • Thread starter Thread starter Emo
Emo
Hello everyone!
I am a good vba user for autocad and I created many subs to speed up my work. I'm in engineering.
I have many macros written in vba for autocad, much math, external excel sheet references, lines creation, polylines, blocks, automatic cards. nothing stratospheric... so
Now I would like to go to vb.net, but reading the English manuals in my opinion give many things for granted. I don't come out much.
by now I understand that if I don't live in .net I'm out of the games in a few years so I don't want to miss the work done in the past but do the porting as soon as possible. :wink:
Can you help me out?
Is there a manual, tutorial to start programming in vb.net for autocad?
After completing my nice program like autocad launch?
What do I use as a compiler?
What do I do to access autocad libraries?
Thanks to all of you!
...... is there a manual, tutorial to start programming in vb.net for autocad? ...
This is the help autodesk on the .net platform:
http://docs.autodesk.com/acd/2010/enu/autocad .net developers guide/index.htmlat the end of this link you will find a videotutorial that explains the migration from vb to vb.net.
http://usa.autodesk.com/adsk/servlet/index?siteid=123112&id=770215real manuals online until recently I had not found them. I don't know now.
in any case you can start from various tutorials on the network. example:
http://www.visiblevisual.com/index.php/autocad-.net/set-autocad-reference-in-net.htmlhttp://www.cadalyst.com/cad/autocad/cad-clinic-autocad-commands-vb-net-5195http://howtoautocad.com/introduction-to-vb-net-in-autocad/for programming on the platform .net then recommend the kean walmsley site of autodesk
http://through-the-interface.typepad.com/through_the_interface/2006/07/getting_started.html
......after completing my nice program as the autocad launch? ...
command netload
sharpdeveloper che è open source:
http://www.icsharpcode.net/opensource/sd/default.aspx
... what references do I have to do to access autocad libraries?...
acdbmgd.dll
acmgd.dll
http://through-the-interface.typepad.com/through_the_interface/2006/07/getting_started.html command netload
sharpdeveloper that is open source:
acdbmgd.dll
acmgd.dll
thank you very much for the links, now I am in harmony with patience and technical English... :finger:
Now I wonder what the real advantages of moving to the .net platform, because for now it seems to me to find only disadvantages ... in the sense that I would like to understand with some example what I can do extra with .net (remaining in the context of use of autocad)
Finally, are we sure that there will be a waft for autocad or will there be a return office type with vba7?
:smile:
:smile:
theoretically it should be the future of programming in autocad, I theoretically say because we are not yet 100% sure if autodesk will not take into account the new vba 7.
on this aspect there are still no noises for the new version 2013.
