project a line in the table
  • Thread starter Thread starter luca984
luca984
hello to all then I would like to know if I can project a line (non-building axis) at the table or if I have to build it by doing all the string (finding the plan that passes normal to the axis and going to calculate the angle and finally given the latter to build a line on drawing cn the same angle) can I avoid all this?? ? pulterating when I go to make a front view is taken only the solid and not lasse that crosses it, which I care about .. thanks luca
Bye.
Your request is too generic.
if you have "physically" a part design line you can show it in the drawing view by enabling the "wireframe 3d" option in view properties; or, if the axis is at the center of a geometric piece, you can build a axis manually looking for the function in the "detail" shovel;
or again, you can use the axes built in part design on your "zero reference" after which in the table, during the creation of the view, impose as "zero" the axle of axes created by you and on that you always create manulamente axles.
we waved
hi mocca I solved with wireframe 3d ..pero sula vista in section continues not to see .
I have another question to ask you; When I join multiple surfaces and make the edge to extrapolate them, it tells me error 336 (both with tangency propagation and curvature) there is one way not to extrapolate them one at a time??? Thank you very much
