donbabbeo91
Hi, everybody, my name is alessio.
I am a mechanical engineering student at the faculty of firenze. I was assigned a project of construction of machines that previews the sizing of a motorboat for boats. I find myself in difficulty because after fixing maximum dimensions and technical specifications I did not receive much information to proceed correctly.
I started studying the structure of beams, but I have problems understanding the correct setting of the project. the professor says to neglect in the calculation the dot that connects the two side "faces" and then possibly verify if this assumption was correct with a software, but I do not know which to use it.
If there was someone who could direct me on a road to follow or who has already found himself making the project of a similar lifting device, I would be very helpful.
p.s. attach generic photo of the object
thanks, greetings
alessness
thanks, greetings
alessness
