leggera Guest May 31, 2017 #1 Hello. I would like to create a sketch using a part with the geometry. only in this together gives me this message and I don't move on. Does that mean?
eugenesis Guest Jun 5, 2017 #2 that you must remove the adactivity in the other together where the part is used
Quoque69 Guest Jun 15, 2017 #3 instead of selecting the face to project test to select the individual edges I in some case have always solved that the geometry is not too complex Hi.
