Sturm
Hello to all,it is the first time I use a forum,I hope to have written in the right section,I have a problem with a university project,I have to perform an analysis on a plate(I am using plane82 elements),I have to get a very precise result of the maximum equivalent voltage(the result is required in mpa and it is required precision up to the 3/4 decimal digit to quano seems...) and I can not get an acceptable convergence by manually honing mesh.
the only command I found through the help was adapt but gives me the following error "adaptive looping is stopped because error norms are zero. make sure that analysis and element types support error calculations".
Therefore I wanted to know if it is the command mentioned above to be used in these situations or if there is a simpler method for meshare at best my plate.
I want to point out that I have already tried to use both plane42 and 82,quadrilaterals and triangles, to divide my area into two parts in order to get mesh more accurate and thick in the critical area, to use a unique mesh with various control parameters on the dimensions of the elements.all these solutions give me identical results only until the first decimal digit but then begins the zig zag...
I hope someone can help me, thank you in advance!
