project images on complex surfaces
  • Thread starter Thread starter geomap
geomap
I'm not a max expert but I wanted cmq to try to do a good job with this program.....I explain immediately....I have to project a high resolution photo on a surface formed by so many mesh explosion that imitates the performance of the ground....this xkè I imported the course of the territory from google earth on sketchup(I didn't know any other way to do it, xkè of this area
select the mesh, in the material insert the bitmap and set the mapping "planar from object xyz", apply it to the object.
Maybe you could apply a modifier meshsmooth to soften the curves
