projection geometries
  • Thread starter Thread starter ROBYTROK
ROBYTROK
Hello everyone
I would like to know how to do with solidworks to project the geometries of a solid face in 2d
this job I usually do it with solid designer but should learn with solidworks
:confused::confused:thanks
Hello everyone
create a sketch on the desired plane/face, select the geometry you want to project then use the "convert entity" command. see the help for details.. .
and what I need
the problem and that I have not understood anything
I usually echo the silhouettes from the dxfs
But now I've been through
x learn have given us a test version of solidworks of 2008
help in simple words
and what I need
do you understand anything and want help in simple words?
explain to me what's complicated about what I wrote:"use the command "convert entities". see thehelp per i dettagli..."have you gone to consult the help where everything is explained "to vegetable test"?
I'm sure you didn't. :cool:
and what I need
begin with the course of tutorials within the program, if not
explaining everything from scratch becomes a slaughterhouse.
learn the names of the functions and the correct terms, will help you expose the questions and requests for help.
the phrases to me of sms are not welcome. :smile:
Maybe it's the case that you put the file and see... you have to get a development? I don't know what you mean by projections of an object 3d.
Okay.
I need to get the shape of the sheet to be cut to the pantograph
I have to get a dxf or dwg
the problem and that I have never used a 3d I have always used autocad 2d because until recently I passed the paper drawings and the dxf and from the dxf I make copy of the silhouette that I need and the neck on a dwg created by me x change the shape as I need,type widening holes where pass tubes or string shapes x leave overmetal where it serves processing
I tried to follow the tutorial and also use the search
But...
I started as well as you, I learned to draw in 2d, but then when the job became more challenging we had to update
buying a 3d, in the case solidworks (which I learned at night... )
the advice I give you is to forget autocad and try to learn by degrees.
the sheet is a field not really simple with 3d, but once you understand the basics you will open a world.
in addition to doing the tutorials present in solidwork, look for movies about youtube. I also have a channel with some videos, nothing but some things are useful for novices.
if you look on the main page of the forum solidworks you will notice a tread "stikato" which is called "useful resources..." where you will find, precisely, links and important suggestions.
also the use of the "search" function, here in the forum, can help you, in fact many
themes have already been treated thoroughly.
convert entities
[youtube]7pgmj0-swb4[/youtube]
convert entities
Thank you very much
