simolrg
Good morning.
must project a pavè built in plant on a bracelet, using the projection command of curve , mapping method.
I did so:
I developed the surface of the bracelet in the plant with the special command, after which I designed the pavè where I wanted to place it and below I projected it in the surface respecting the reference data. everything worked egregiamente in fact the program projects well the curves, but in reality it tends to ovalizzarle forms in a direction ... how can I do to make the projection more precise?
es: I projected a circle and looking at it from the top you see that it is very ovalized.
cordial greetings
wide simon.
I did so:
cordial greetings
wide simon.
