projection on 2d tilted holes
  • Thread starter Thread starter Sbilf
Sbilf
Hello everyone,
I guess there's no way to project the axes of the tilted holes on the catdrawing.
the axes of the "paralleles" holes on the projection plane of the views creates them correctly
If you find the solution... thank you all.
ps. I know that there are other ways to get around the inconvenience, but I would like to encourage ds to overcome the problem.
in the world of moulders the problem is annoying
allego files r19 for vs controls
Hello sbilf
you must add them with the axis command where it does not put them!!!! ! ! ! ! ! ! !
and you will see that it works:
Hello
thank you, but as I had already indicated in my post, I am already aware of other ways to bypass the "good" of v5.
with the costs of v5 this seems to me a flaw not recently...
Sbilf
Hello
Sbilf
I am not sure it is a v5 hole; because he the hole I see it as an oval and not a circle!!! ! !
I'm curious to see the other sw how an iges behaves
Some colleagues will help us with some tests
No one else trying to do this test with any other cad??????? ? ? ?
the same views made by sbilf with the same model attached in iges
