projects
  • Thread starter Thread starter stefanoart
stefanoart
is it possible to project a surface on a surface?
so that the second (the one that must be projected), deforms to follow the profile of the first....I was a little prolix, sorry.
on the surface, "transforms an object from a base surface by adapting it to the shape of a reference surface". from the guide.
I don't understand.
But I believe that using the boundary of the surface to be projected, and projecting it on the other surface, you can get what you want.
I don't understand.
What stefanoart probably meant is to project a polysurface on a surface.
creates a complex polysurface (magari in piano) and then evvolge it on a bombed surface. (see image)
the command is exactly the one indicated by enri :smile:
Wow! I don't use rhino..., fantastic!
It's just what I want and I'm glad it's for others.... but I can't find the command! ! !
menu transforms -> swipe along the surface.
udt icon panel, is the first, with a blue skeptical rectangle.
