promechanica lite - press on surface portion
  • Thread starter Thread starter NightHawk
NightHawk
Hello, everyone.
I have to apply a pressure on a portion of a solid surface.
I currently model the solid in a standard way, then create a surface through sketches in the area where I want to load, and then apply pressure only to this surface.
Is that correct?
thanks to all
you can use the "surface region" command directly in pro/mechanica (in the single part). guides you in creating a sketch directly in pro/mechanica so you can divide as you think a surface. At that point you will apply your force (or pressure) to the area of the surface you have divided.
there is also the "volume region" command that allows you to divide a solid part in order for example to increase the meshatura only in that porzioen volume you have divided. idem of course for the meshatura of the surface I said earlier.
is it possible instead to distribute a force on a volume?
you can distribute it on the counter of the volume created as "volume region" (analogue of the "surface region"), if you want to distribute it in the solid you must invent a mass force (inertial) applied to a body defined separately (I believe in standard mode, not in prom, but I am not 100% sure).
But isn't it a little weird? ? ?
I had thought of putting a gravitational load, but so doing all the components of the axieme will be subject to it, instead I have a magnetic force that only acts on one.
Actually "trucks" of this type are normal in the "sector". I would say that prom is indeed one of the best.. .
it is not true that all components of the axieme will be subject to inertial force: just attribute the real density only to those "desired". among other things in prom there is the possibility to distribute the loads with parametric laws, could come back useful.
Last consideration: if you use the "lite" version it is clear that certain advanced fem entities may not be available.
Yeah, I agree, too! pro/e nr. 1 always
in the company we are working with ansys from command line, a real tragedy
