properties beam patran and bar orientation
msperanza
I wanted to ask why, when I apply the beam property to a curve, you do not see the 3d representation of the beam, as it happens in some tutorials I have seen. Do I have to set up some options in particular?
Moreover I do not have clearly how to orient the beam (for example for a curve that goes from point (0 0) to point (1000 0 0), what value should be inserted for the vector bar orientation, considering that the section of the beam is on the yz plane?)
