MARCOC
hello to everyone and good year
in sti days I noticed that by putting the default material of solidworks appears a property (descripion)
that if you delete it and try to put it back from the list, no longer exists, I found that it only fills up when you set the check in the configurations
Is that what you're going to do, and why once you delete the column, there's no way to make it reappear? ? ?
Thank you very much
Is that what you're going to do, and why once you delete the column, there's no way to make it reappear? ? ?Thank you very much
