prospetti e shadow
  • Thread starter Thread starter Sofia1234
Sofia1234
Hello, everyone! I have to make a black and white prospectus with archicad and then possibly import it into autocad.
- the prospect appears to me all colored (orange seeds by default etc), how do I make it all black and white?
- the prospectus should have black glasses and then the shadow, only that I can't sample the glasses, can you actually do with archicad?
- if I amount the dwg-format archicad prospectus, I don't even read the layers, if instead the pdf port is all sampled. How can I solve this situation?
thanks in advance
the prospectus should have black glasses and then the shadow, only that I can not sample the glasses, can you actually do with archicad?
I don't know Archicad. Maybe for glasses it is good to choose a solid sample, that is a uniform color, and then set a transparency, or however to use a very soft color. transparency however helps to attenuate the color chosen for the glazing.
As for the final result, perhaps it would be more elegant a result in gray scale, rather than the black and white real. in the grayscale printing the glasses should be represented with a light grey and not in black. something like that: I repeat, I do not know archicad, but to export on autocad it is necessary a precise procedure so that autocad does not encounter difficulties to interpret the design. I found something on youtube
