MORENO100
Hello everyone,
I look for solution for this strangeness (work with wf3).
I work in a set, assemble my part that must be a ø14mm tree extruded up to a reference plan of the assembly, placed at 2m from the assembly plan of the part.
the thing seems trivial, but the proe does not allow me to do this kind of feature! ! ! !
theory: I believe that the proe has problems in making small round protrusions (in my case <ø14mm) extruded for propositionally long lengths, for example ø14 extruded up to a surface of 2m.
tests carried out:
1- try to reduce ø <= 14mm >>> > does not work.
2- I try to increase the ø above 14mm >> > > > > works.
3- I try to change the sketch by deleting the circle and drawing a rectangle even of size less than ø14mm >>> >> working.
Comments: I thought of solving the problem by bringing the relative accuracy of the part and the together from 0.0012 to 0.0001 but it does not work equally.
thanks to anyone who wants to help me.
tests carried out:
