prt x prt
  • Thread starter Thread starter brasiliano
brasiliano
How do I import a prt made at my house into a prt in the company? ? ?
pro/e - wf2
ps. the prt of the company has special parameters, instead my not!
Thank you!
friends, let me explain!
I created a part with a startmodel. I want this part to be in the startmodel of the company, okay?
I don't understand, can't you create the same parameters in the star part you used at home?
open the business part, go to parameters, select them all and copy them.
in your part go into parameters and paste the copied data, paying attention to select the same number of rows and columns.
okkio also to relationships and possibly also to the reference plans that should have same order and name...
Friends?
for parameters, all right!... I understand
but there are also:
- unit (mm x in)
- levels
- tolerance(s)
and other things I don't remember right now. . .
it is not possible to do all this by hand, because I can halve something!...right?
Hello Brazilian,
try this way:
1)creates an empty part with the start part of the company
2)copy all features (including squares and reference boards) from the prt template tree you made at home and paste into the vacuum prt
3)pro-and will ask you first if you want to scale the model and then place the main plans of reference of the prt of the house that you will be siding coincident with the main plans of the company prt
4)The game is done!
The solution is a bit brutal but it should work otherwise... you will have lost 2 min! :
ps: I do not know if it is influential but to copy/paste the tree I use ctrl+c/ctrl+v
