publication axis hole
  • Thread starter Thread starter MAXUS
MAXUS
is it possible to publish the axis of a hole?
when selecting the circular face (generated with the hole command, then canonical) in the publishing options I can not understand how to allow the publication of the axis :confused:.
when I go into an anxious assembly and select the constraint (axial), the axis of the hole in reality is not published.
of this I notice because if in the tools-options enabled the flag that allows to bind only published geometries, the axis of the hole is no longer a selectable geometry.
Am I forced to build the axis with a segment?
thanks to all
It is possible,
you have to tilt your hole and then select its surface -> other selections -> in the window you go to search for the virtual axis -> publish it
