New Rider
Good morning to all,
Currently, in my application, I have a system of ''ammortizzzione'' consisting of a cylinder and a stem (like fork motorcycle). at the base of the cylinder a pressure of about 1/1.5 bar is applied. This pressure moves forward the stem which, once reached its position (maximum output), maintains it and at the same time in case of force against this pressure it acts as a shock absorber. to retract the draining shaft and manually retraggo. Good. At this point I don't want to let it go manually but I want it to automatically retract.
I could create a double effect cylinder but, given that the cylinders are of our production (they are not as iso cylinders)
I thought I'd use the vacuum technique. at the moment I have the need to make all the active stem the vacuum system so that the stem comes back everything.
Surely I will have said some chestnuts given my unknowledge of the empty sector.
you have any ideas or links to recommend.
I checked on the vacuum site but we always talk about pick and place motimentations and what else.
