rinato
Hello, I have to anticipate a job that also contemplates the junction points between 2 sheets 10/10 obtained by pointing (I hope it is the correct name, since the machine is called pointer ). But the customer asks me some kind of guarantee on the mechanical seal of the joint.
the welded box is the casing of an arc welding machine (electrodes), so the casing is mainly subject to mechanical vibrations due to the operation of the electrical components. statically, it only has to hold its own weight.
The customer, on a targeted demand, cannot tell me what standards to refer to to to assess the resistance of the welded joint, under those specific conditions. they have already experienced that the only points (of other third party) were not enough and over time added "wire" traits. Now they want to be able to eliminate these last...
Can you tell me what to look for, as a rule, to avoid hurting me?
Thank you, reborn.
Thank you, reborn.
