put into the table of a set including other puts at the table.
  • Thread starter Thread starter valeriob
valeriob
Good morning, everyone.
I try to clearly broaden the title of the discussion.
modeled a group that takes part, together with other assemblies, of which the table has already been put (of the single part).
when I go to make the boarding, I would not + do the
put into the table of the individual parts (yes made), but include them in the sheet of the new table, keeping them "delete" to the part file
that any modification made on the solid part is applied
at the table of the part (as already happens) and in all the boards where the table of that particular part is located.
a kind of past copy of the putting into the table of a part in a table of a set.
In my opinion you can succeed by copying the sheet or sheets that compose the tables of the parts and paste them into the board.
this cap and the connection between the table and the part, but I don't think you can keep the connection between the table of the part and the glue sheet in the axieme.
I'm sorry, though, if I allow myself to tell you that what you're doing, it seems unhelpful to me, because if you have a separate axieme, it just takes us to look for the table of the single part.
If you want a table that includes all the others, then I would recommend you to make a pdf including all your tables. starting from the assist and coming to the single part.
I quote what Kakisan wrote. if you want the views of the details boards within the board board you can also copy and paste the individual views. that is, open the table of a particular, select the views and cups, go to the table of the asses and incolli. a little as you do in carpentry by recapitulating the plate inside the welded brands.
