quality of the axieme
  • Thread starter Thread starter Dottor_Scott
Dottor_Scott
here I am again asking for info
I am realizing what I can define the first 'serio' work
with nx and I noticed in the axieme a low quality of representation
in shaded mode. I have noticed that the circles appear as hexagonsAppunti02.webp,
can be represented correctly by pressing dx key and choosing
'show exact element'
but there is no setting that improves quality?
I tried to change the settings in preferences\visualization\ setting
all at high quality but the view does not change
the worst thing is that if I do a section, the view is so
poor to make it look, so much to make an example, a 'eccentric' hole
(in the lower part there is interference with the tree, in the upper part there is game)
while the odds are fine.
Can you help me? thanks in any case
Dear Dr._scott, far from me refuse to give a tip to those who ask in the forum, but certain questions, and above all certain conclusions, seem very superficial to me. It's like I took a 200-cv bike I climbed over shooting and then ask where the arrows are!
what you see in nx depends on two aspects: one in the loading of the components that can be lightweight or exact and must-can be set in the loading options, the other in the regeneration of the views: dx button on a blank part of the update display screen.
I hope I've been clear. Hi.
dear baskets1959,
I'm aware I'm missing some basic information on nx, but what do I have to tell you?
I did a course with instructors siemens more than a year ago, days when I didn't even have
available the software. then the license came, but for internal needs remained there,
Unused.
today I am facing a pretty demanding design, the customer
demanded modeling with nx, assistance
has not been renewed for budget needs, I only remain this forum.
However be patient only another month:-) administrators have assured me
to renew it by March
What conclusions would I draw? Sorry I didn't get it.
It is true, the 'use of light representations' option was set: concerning in
notes that I had taken to the course, in fact it was one of the first things that they had told us.
hi Dr_scott, the conclusion is that 'assieme has a low quality of representation'.
said this even if you were in maintenance certain answers do not give you as you can report problems but do not ask how to do something. unless you find good moon care that gives you a tip.
We arranged to give a hand and two. (iii)
ah but the low quality of the axieme was said as 'made given' but not as
I thought there was an option somewhere.
for assistance, the only two times I resorted to were kind, one
even made me the required modification and sent me the correct files.
Go, thank you, I'm going back to work.
preferenze visualizzazione.webpI've solved so in his time. changes from "part" to "view" in the drop-down menu that I highlighted in the image.
mmm on 8.5 the window is a little different, I see that it is missing
That voice, but maybe I'm wrong, and I can't even update the
version, the supplier imposes me 8.5
However in June I will have the 10
in every caqso thanks a thousand of the council
good evening boys, even if with a little delay than the date of the post :roflmao:, I find myself in a situation that I cannot solve:
my 3d model is very detailed, I managed to set the ultra fine quality, but my problem is in the quality of the selection or, when I pass over my component with the mouse the selection is very low quality.
Does anyone know which parameter to set to solve this problem?
