arm
Hello, everyone. I just started using t-spline 3.0 in demo version.
until now I have used rhino for basic solids and silo if I have to make organic forms. silo is very simple and intuitive but ultimamanente crashes very often (both on win xp and on win 7) and above all does not have the precision of a cad, since design artistic models for cnc. t-spline seems to me a very good alternative, but I have smooth-related problems. I attach image.
I drew a circle and extruded with "scale", then I selected a edge and in turn extruded it. Then I extrude again along the z to give thickness to the solid, but the smooth leaves and leaves me a sharp shape. I also found this problem by drawing a simple t_sphera, I select a face and the gate and he loses the smooth. if I then re-extrude the edges of the hole it softens. or better, if I leave from a solid base closed and I go to edit it by extruding directly the faces, all right, if I gate some polygon goes into the ball, I can't make the solid "soft". Sometimes other things don't, I don't understand where the mistake is.
Does it happen to you?
thanks in advance
thanks in advance
