question about the 2011 version.. .
  • Thread starter Thread starter Carvalho
Carvalho
I checked if it was already posted, but I think since elementary no one has ever made it.. .
I approached revit with the past version, with this new I noticed in the voice "muri" that the variety of elements available for creation are much lower than those I used...now, not remembering if, for 2010, I had made some update, so I ask you if the standard equipment is so scarna or if you can implement with already ready walls by downloading them from autodesk. the same goes for the continuous facades.
thank you and excuse for the cretin question... soon
Yes, but as soon as I posted I immediately answered myself... thank you, I will have to take away a lot of things:)
See you soon.
to specify:
continuous walls and facades are system families, the implementation of such families is done by modification and rename of the default ones.
the types of wall, you can transfer from one project to another (or to the starting template), with the command "transfer standard ...."
