Question/Mistress
  • Thread starter Thread starter Entità_vettoriale
Entità_vettoriale
Hello, I wanted to know if there exists (and if yes, where is it?) a tool similar to 'interrogation' of autocad on 4d cinema? or a tool to determine the size in length from point to point b?
thanks in advance
seen now.. sorry.. :4404:
Is it a plugin? I do not see it, with what versions is compatible?
cmq I only knew that there is also the measure command.. will not make quotas cmq is better than nothing.. :
I forgot.. Thank you. ♪
It's a xpresso movie file, it opens with versions of cinema from v11.
other solution: I attach an image to build xpress that from the length in a design unit of a line, use 3d snap and point to place the line on the solid points to measure.
I hope I've been helpful, bye.
