quota filetto
  • Thread starter Thread starter Cla
la macro per wf2 per inserire la m nella quota di un filetto.
copiare nel config.pro:
mapkey _qt_fill @mapkey_nameaggiunte il prefisso m\nalla quota filetto;\
mapkey(continued) @mapkey_labelm;~ select `main_dlg_cur` `menubar1`1 `edit`;\
mapkey(continued) ~ close `main_dlg_cur` `menubar1`;\
mapkey(continued) ~ activate `main_dlg_cur` `edit.psh_dwg_props`;\
mapkey(continued) ~ select `mod_dim_asynch` `tab_main`1 `lay_dim_text`;\
mapkey(continued) ~ focusin `mod_dim_asynch` `inp_dim_prefix`;\
mapkey(continued) ~ input `mod_dim_asynch` `inp_dim_prefix` `m`;\
mapkey(continued) ~ input `mod_dim_asynch` `inp_dim_prefix` ``;\
mapkey(continued) ~ update `mod_dim_asynch` `inp_dim_prefix` `m`;\
mapkey(continued) ~ focusout `mod_dim_asynch` `inp_dim_prefix`;\
mapkey(continued) ~ activate `mod_dim_asynch` `psh_ok`;
Sorry, but maybe we didn't understand how to use cosmetic fillet.
Anyway:
in a screw the thin lines are those of the diameter of hazelnut.
in a threaded hole the thin are those of the nominal diameter of the thread.
and therefore it is not true that the thin ones are always that hazelnut, that it is vine or medrevite.
Bye.
Yes, I was wrong to write. . .
I mean it just like you.
cosmetic mothervirte as greater diameter.
cosmetic screw as a smaller diameter.
the reference to you was in relation to the council that was given to you by dema.
I understand that by necessity (especially in the analysis of interference) it is convenient to manage the thing in a different way...but the representation that comes out is wrong...so I do not approve it.
Okay, Lollone!
All clear! ! ! !
I am a neophyte of this site, I discovered it a few days ago looking for a particular info on angular tolerance... And I found her here.
It was like a child to be in a nutella tub! ! !
I don't know who to compliment this site... so I express with you this satisfaction. . It's spectacular.
Hi!:finger::finger:
look...I just tell you that I learned a tide of things only thanks to ozzy, maxopus, prof and all the pro-and slenders that are enrolled in this forum and that help the neighbor for the only pleasure to do it!
thank you, I also thank ozzy and prof (my first interlocutors).
I also thank the administrator, without any time this meeting place would not exist and the supermod sandra ... that I think is doing a great job.
since there is she the forum goes much better and clashes have decreased considerably.
