quota from preset level
  • Thread starter Thread starter Solidworker
Solidworker
Good evening.
I'm drawing a section in autocad.
I would like to create a level quotation, starting from a level set by me (e.g. land= +/- 0.00m) and bring out the various quotations for the various planes (e.g. first floor = +0.05m, second= +2.80 m and so on).
is there an automatic method to make it not to make an aligned quotation next to it?
Here's what I need (paint :rolleyes: )Sorry about the bad picture.
Any other ideas?
I had read somewhere that you had to change a quotation style but no more regret how to do:/
Try to see in the help (also workshop on new features) if you find something.
I never used them, I'm sorry.
I have already tried to search on the network but I have found nothing specific.
we hope that some other user has already used this tool!
Hi, I had realized this time agohttp://www.cad3d.it/forum1/showthread.php?t=9758using a block as a symbol.
I then modified it with this autolisp program.
without need of blocks and so that the writings (mtext) mask the objects below.
see if it can be useful
after uploading
(infosinbquota)
show a short guide
Even if the textbook is really nice, I've been doing this for a long time.
It's a dynamic block with filed in centimeters.
just insert it and place it. selecting it will appear two grips, the first to be moved in the 0,00 on the design and the other for the position of the quota itself.
launching the regen the quota is updated.
very good:finger:
right an info: how did you associate the text with the block parameters?
Bye.
then first of all thank you for the answers.
I tried the program in vlx but I can't use it very well. the guide does not open with infosimbquota.
the dwg file, however, goes well but if I have to consider for example 10-storey buildings? How can I change to get a basic point and then all odds?
edit: with a paste copy start from the quota that I put before and set the others. I think it's okay.
Thanks again and hello! ;)
for the guide you have to enter
(infosinbquota)
including brackets, however in the name of the function I incorrectly entered a n instead of the m
infosi "n" bquota
This is the short guide:
from command line:
"quote" to start with the settings set; "-quota" to change settings.
options: enable by typing the respective uppercase character.
- Heighttext: font height and therefore symbol size;
- numdecimali: decimal number displayed;
- quotarif: basic reference share for vertical sections;
- vert: vertical quota (sections);
- horizontal quota (planimetries);
- rough: symbol with sampling
- finished: symbol without sampling
- insert: preset option, just click Enter.
- This guide
for the vertical odds after insert is required the position of the symbol, click left button mirrors the symbol.
for horizontal quotas after insert is required the position of the symbol or typing a numerical value to change the quota, click left button mirrors the symbol.
wanting you can upload the .mns file with the "carmenu" command that will make you appear a toolbar with icons and commands
first imposed a point 0.00 or other value as a "quotarif" reference to which I admit the value and the subsequent points will be represented with the reference value.
I hope I've been clear enough.
(infosinbquota)
infosi "n" bquota
from command line:
- This guide
Bye. I only noticed after there was a m.
Anyway now I try thanks a lot of directions! :wink:
Bye.
It works perfectly. That's what I was looking for. You know just how to put the word "m" on the side? What do I need to change the source?
Bye!
the symbol is a "anonymous group" entity composed of deduction flannes and testom
to edit the text activate the property tab (ctrl+1) select the symbol and in the selection combobox will appear
all(8), scroll to testom(2), in the text pane to the content field you will see *varie* by clicking on it you will activate the editor of the textm.
You will see in the editor the text to edit.
with ok steps to the other empty textm, which I need to mask the objects or lines below the symbol.
with other ok terms.
other possibility is to explode the group (see group command options), but so when you move or mirror the symbol you have to manually select all the elements of the group.
the vlx source is compiled and is not editable.
Bye.
