quotas and isocurve in the table
  • Thread starter Thread starter poldo
poldo
There's one thing I've always wondered, but I've never looked into.
it is possible to make the "messa in tavola" with rhino of the "prospect", including in the visualization also:
quotas
Isocurve
would be very helpful
quotas
Isocurve
I'm not very clear about the question, if you want to know if it's possible to share the perspective view after using the command that creates the table... the answer is yes.
If you want to know if it is possible to quote in 3d the object and then print out a perspective view with those odds...the answer is yes (see attached image)
If you're losing something else... then I don't understand...
I mean:
- model my object
- the ratio in 3d
But then when I make the table of the perspective view, the odds and isocurves disappear (not from the 3d but from the 2d drawing of the table).
in the image that you attach to me you only see an item 3d quoted and not a "board" with quotas.
...and then print out a perspective view with those odds......(see attached image)
Here, you have printed a jpg or pdf.
I have to "put on the table" and then have a vector file to export to other software, while of the simple quoted jpg I do little.
I mean:
- model my object
- the ratio in 3d
It's not possible what you want to do. with the command "messa in tavola 2d" only the quotas that stand on a plane parallel to the projection plan, because only these can be reported without being deformed. . .
