quotation in different scales
  • Thread starter Thread starter matteoprincipi
matteoprincipi
hi to everyone, I open this discussion to ask for help on the question quotas that for a couple of days creates problems (I have already looked for similar but without success!).
I explain in brief:
I have a table on which I have drawn several objects that have very different dimensions (e.g. a mirror from the ground and a frame for photos).
for obvious need of proportions I have to create print viewports with different scales (e.g. 1:10 and 1:1).
here arise my problems: if I quote the objects directly on the glossy design the nn quotas can be seen xché too small (I have drawn in scale 1:1), and when I then visualize the viewports in different scale the nn quotas resize, therefore remaining small.
if I quote in viewports the dimensions shown are those relative to the scale and nn to the objects (e.g. on a scale 1:10 the quota will be 10cm instead of 100cm). Also I must always go on changing viewports as when changing crop and is very uncomfortable (as well as a great loss of time!).
Maybe I raised a very trivial problem, but by using just vw nn I found solution, could someone give me an explanation? ?
Thank you all! !
to solve your problem edit viewports and add odds and notes inside the annotation/annotation mode
is not a waste of time; is the only way to have odds and notes of the same size even changing the scale to viewports.
as you have already experimented, if you quoti in design layers/polished design, by force of things, viewport to different scales will have quotas with text of different sizes.
if instead quoti directly in the sheet layer/lucid presentation risks inaccuracies because the share does not recognize the snap points.
I do.
Good morning lory and thank you for the answer.
in fact then I have to jam a lot of tables and having very tight times last night then I did up as I told you and up separating the drawings in multiple files (in order to be able to adopt on the design layer the same scale of the presentation :tongue:
but a way to change the size of quotas with its text nn is there?
Moreover another thing I noticed is that obviously drawing without quotation if I have a couple of close objects when I go to edit the viewport by inserting the quotas risk having everything too sticky....for if I return to the design layer and move the object, returning to viewport the quotas remain in the same position, thus losing the association to the object itself....right? How can you handle this problem?
regarding the snaps in fact I noticed that they are recognized with more difficulty, but by doing a local zoom I also have the lines of the drawing much thicker....xché? nn can you have the line always thin even in the viewport as in the design layer?
thank you for the availability and excuse me if I ask a lot of questions, but since in all the posts I have read you are always the one who responds... .
Matteo
Why did you separate the designs in multiple files? Do you know that in a same file you can have gloss/layer at different scales?
select quotas, go to the text menu and select a different body size.
quoting in the annotation space
if scale changes also change the thickness of the lines.
edit the categories/classes of viewport and reassign the necessary thicknesses.
However, the best thing is to insert the odds into the viewport annotation/annotation space, thus duplicating them, changing the scale or moving them not risk losing them or changing the size.
I do.
in the 2011 version you can create text styles. these can also be assigned to quotas, from the editing window in document preferences.
before this version or, however, if you do not edit by assigning them a style, the odds take the default text formatting of the document (menu text ->formato testo)
I do.
does not exist a method to be able to set it directly on quota styles? and what about the font is this case?
if from the quota preferences panel create a new style of quota (with all the settings you need) you can, once created, recall the command "standart odds replacement" that does nothing but look for the odds with the style to change and change it with a pre-existing style or one created by you. In this way you can also set the text.
