I forgot the picture... that I'm pissingI didn't understand how you'd share the 5th
I think 138,5 should be put because the encumbrance should always be indicated. then depends on the context if to put them as nominal or auxiliary.ok, the 138,5 put as a nominal quota indicates that the sum 85+r53,5 is not enough to make it understand that the line is tangent to the semicircle, because if so it was not 138,5 I could have it for example to 137,5 and perhaps it would not understand (the incidence)...I do not know if I explained...I guess the tangence is not to be considered actually discounted
tangency is visible in theory, but if tagency is apparent (almost tangent) it is better to indicate it with the appropriate quotas. ..however the encumbrance always indicated ok... as an auxiliary because if the tangence is given by defeat I already have the ray quota and the one from 85I think 138,5 should be put because the encumbrance should always be indicated. then depends on the context if to put them as nominal or auxiliary.
as to whether the radius and the tilted line are tangent any designer and operator simply deducts it by looking at the design; But as I said if I had to redesign it to give the dxf to the thiefist I prefer to have on 138.5 rather than 135.77.
the 5th is quoted on a theoretical line that cannot be measured, but to know if it is to be considered valid you should know the function of the inclination; if it has to be controlled then is correct that 95° that you put at the beginning.
priority must always be the functionality of the particular.
so to say, knowing that it is a particular laser cutting product and that the dxf you supply half of those odds do not even serve and you could only put those processing of the particular welded and those of control.
