biz
in this case not sure, only of fresa. Anyway, I decided to quote "old".could be obtained from laser cutting or oxide cutting
I don't think you have the width in your tab, in your no.always depends on how you work, whether you use the compensation or not. I don't see big limits from this point of view.
true.conceptually it is the same thing though.
you start from the idea that everyone uses a cnc cutter, but if I have a 40€/hour manual cutter and you do not require tight tolerances because I have to use a 100€/hour machine?always depends on how you work, whether you use the compensation or not. I don't see big limits from this point of view.
But the debate is not about that. I just wanted to figure out whether it's formally correct or not.you start from the idea that everyone uses a cnc cutter, but if I have a 40€/hour manual cutter and you do not require tight tolerances because I have to use a 100€/hour machine?
