quote detail view
  • Thread starter Thread starter abro
abro
I tried to search but I can't find an answer,
Wanting to insert in a detail view the quotas of the diameters does not make me insert them, is there any solution? Thank you.
Can you capture what you want to do? You should specify a little better to figure out what doesn't work.
if I have to duplicate the detail, only circle + b without sight
How can I do that?
If I understand correctly, I think you have to create a new full view with increased scale, and then use the "interrupted view" command on that same view.
I actually had to create this, I made it designing it I thought there was a faster system.1695022442278.webp
but is this representation correct?
Obviously not, it is a simplification from carpentry. in this case it is better to put a simple note with written "work as detail b".
I do not understand the usefulness of quota 1, which among other things refers to a hidden element and would therefore be avoided.
that quota is inserted to help the cianfrinatura that takes account of the angle and the distance of departure precisely the quota 1, rightly to design would not be correct should do a section, but for convenience, speed ....
