quote directly 3d models in autocad lt 2016
  • Thread starter Thread starter ascaro
ascaro
Hello everyone,
I did not find in advanced research if and how it is possible to directly quote 3d structures in autocad.
for work, I use a lt 2007 that while not being 3d allows me to view solid models and to manage the main views - above, below,fly,etc.- and even to quote directly on the intersected view.
with 2016 I can't do the same, paradoxically.
Can any of you tell me how to quote in 3d how do I do with thelt?
Thank you in advance!
works the same way. you say you can't but you don't indicate why... explain us better, otherwise it's impossible to help you
Uh... I'm trying to explain better, okay? practically with lt 2007 the dimlinear command allows me to quote directly on the solid, for example to detect a measure of an element. Obviously if then I roar the view, the quota 'disappeare' being arranged (jacendo) on a different plane. How can I do the same on autocad 2016? I usually use the 'flatten' command and then quoted on the flattened object.
