batstar
Good morning to all,
I have to put on the table a sheet that has two edges with bevel, has a quadrilateral shape derived from a set and therefore its plans of origin are not parallel to the faces of the sheet, I then customized in the ipt the view "top" and "front" parallel to the faces.
putting on the table when I go to position the odds appear to me skewers, as seen in assonometry, parallel to the faces of the bevels. I can't place them properly and not even on a missing angle, when I go to position a quota with apparent intersection you can't create it. Is there any function I don't know?
