r2w: management multibody parts codes
  • Thread starter Thread starter strudeldemele
strudeldemele
Good morning to all,
I am beginning to use ready 2 works (pdm for sw 20017) and I have a problem with multibody parts:
How can I manage the encoding of individual bodies? I should make sure that each body has its code, the family changes depending on the preparation (a laser cutting body will have different code from one piece only cut or cut and milled)
- I would like to avoid entering the separate cut and inserting each single code by hand, and so doing I think I can't recall the individual codes or create automatic steps
thanks for the friendly collaboration
greetings and good evening
Multibody Welded Management is included in the premium version, you must check that your license is this. in this case with the "capture components from solidwroks" function you have the ability to create a part for each different body, codify it and manage it as any other part.
