michaeljack
Hello, everyone.
Have patience, I'm learning to use v5 cat and I can't figure out how to make a radial hole to a cylinder.
with pro/e it is sufficient to select the cylindrical surface and then two references, one for the angle and the other for the distance.
as seen in the attached image the hole was reported on the front floor with a angle of 30° and a distance of 20 from the top surface of the cylinder.
What is the procedure to be done with catia to get an identical hole to the image?
I hope in your help... thank you all for the support you give
