edos90
Good morning to all,
Surely it is a sad and retrite subject, but I would like to start a discussion to try to understand how and if it were possible to do better.
I have just delivered a permit to build for a small building thanks to the support of an expert in the craft (which I thank very much in case you read me)
the result in regards to you and surfaces was great but I would like to understand if you can do better.
we managed to create an automated table for the rai, despite the numerous problems due to the multitude of parameters required by the Milan building regulation but accepting some graphic compromises
http://i.imgur.com/eyogmhf.pngI would like to understand if it is possible:
- prevent the local area and name from repeating when there are two or more windows.
- highlight the total result for each room more decisively.
but the real problem is the demonstration of the surfaces that were made through the export of a report on the premises. Apart from the fact that it is not possible to organize the export in a bim way (I had to eliminate for each floor all the premises not interested to export the single apartment and avoid that they were all piled together) the result was a bunch of about 250 pages definitely not practical and difficult to consult.
Is there another system? How could you do that? How are you doing?
In short, I should work on a project 10 times larger and the idea of making the demonstrations of the surfaces so it directs me to suicide :
Thank you!
Thank you!
