sampom
...tutorials, help and guide online. There's everything.I don't even know what it is. I don't even know what it is. !
look inside the menus (all) and try the commands.. quiet that does not break anything
Mar
I wrote it yesterday, Saturday afternoon. :tongue:sampom, okay, it's Sunday morning melancholy,
..already... pity that there are more than 2 wolves to separate us; I wish I had your "malinconia" :biggrin:I also have certain Sundays awake and regret when I was jogging with the sender instead of gps
you have to split the lever into multiple sketches when you have a change of extrusion thickness.You guys are in the middle of what I did... What do I do?? the right side can't continue it!! !
....I did theitis in a transition phase, those few hand-made tables were masterpieces with so much of "coal smoke"/"then for the success of a table also wanted a nice dose of "manuality" and passion (even a little artistic in some respects)... all things forgotten (unfortunately). "
If you designed the previous extrusion on a main floor use that. otherwise first you create a plane parallel to the passing face for the middle point. then mirror.the fact is that in the sheet the quotas are put to [Bleep] of dog and you do not understand anything!!! for example in the right part of the piece there is a radius of 19. If I put the radius of 19 here is how it comes out (I attach the photo capture1)... and then I wanted to ask you another thing: look at the photo "cattura2", how do I mirror the left extrusion (that curve) to the right?? ? Instead of creating another sketch equals to the right, it seems easier to mirror the function. select the extrusion function to mirror but then tells me to select a plan in which to put the mirrored extrusion, I can not position the new extrusion well. . Sorry if I ask questions so dumb but I really want to learn how to use this program well and I don't have time to do it by looking online guides or whatever... I've got the exam soon.
