Quaever
Hello to the community,
I am a student graduating and I would need to learn in "fretta" to use basic autocad commands to reproduce a digital model of the terenno.
are in possession of:
- autocad 2013
- road map 3d 2013
- a .dwg file, representing the 1:5000 technical card of the area of interest.
the dwg file includes legend, labels and obviously level curves and listed points. from the properties of the elements of interest, I see that in the item elevation are all set to 0.
My purpose is to extract from the dwg the isoipse suns and quotated points, change the quota attributes by inserting the correct values, create the digital model of the soil with 5 meters pitch.
I know it's a lot of stuff, but I'm just a little bit of a day's experience, and I don't ask to step through all the directions, but at least get some tips on how to proceed.
I was advised to work on dxf files, but when with autocad "Save with name2 in dxf, if then try to open the file itself nothing appears.
I also know the shp format that I use on qgis software, and on the latter there is a plug-in that converts the dxf into shp, but loading the dxf, produced by me with autocad, gives me a mistake.. .
practically in the dark, even for the total absence of software knowledge.
thank you so much for the attention and hope you can "help me"
- autocad 2013
- road map 3d 2013
