asblo
Hello everyone
I have a problem with a derivative part. is the code 58.99.99 you see in the image. was a skeleton part with several sketches that I used as a matrix to get the other parts. by making a rename in the folder, for some dark reason it has erased!
now they are without skeleton, opening the parts that used the skeleton, on it appears the "?" because it does not find the file, however the references are all correct, all the plans and sketches of the skeleton are still "live". my question is therefore if somehow you can recover the file from the derived parts... if the references are still alive obviously still exists in the multiverse.
I also attach a file of a derivative if some good soul wants to try.
